ff <img src="/ubbthreads/images/graemlins/lezen.gif" alt="" /> en dan kom je wel verder , en dat is toch niet zo moeilijk??
Tot morgen maar weer <img src="/ubbthreads/images/graemlins/wink.gif" alt="" />
  • Reacties 339
<img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" /> @ Alfa One
Settings.ini aangepast werkt nu perfect
<img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" /> Thanx
Dreambox 8000HD, Breambox 800HD, Wave Frontier TD90.
Voor diegene die geen duits kan begrijpen hier een Engelse versie.
ToH 3.2 with EMU 1.2 (by HoT)
Following CAS-Systems can be now emulated:
- IRDETO/BC
- SECA mit
- SECA2 für Ident 64
- VIA
- NAGRA mit AU
- CONAX
Before installation please read the following notes:
The HDF-Datei HoTEmu****.HDF derives from the Basis firmware and the TOH-Module, like Emu. The HDF-Data will be installed with the download tool WDN40AK+.
After installation of the HDF in the Humax, input also the EmuKey-File. Also use "DSR 9500 EMU Ed23.exe".
Attention, The Hummy has to be on , and not in standby mode.
To write, use the write button. Please check with 'Read' for the first time if the written keyfile has been uploaded in the Humax.
WIN2000 users might experience problems.
After installation, one should put the Humax in Standby mode.
Now will the keyfile from the RAM be written into the Flash.
Please Note: After uploading of a new channel settings, one must reinstall the EmuKey-File. One can also use as Human from Version 0.9.9.1.
Human was written especially for the HoT-Firmware and doesn't overrule or alter the Basic Parameters any more.
Please Note: A card has always to be present in the CAM, at least untill the Card Initialising stops. It is also possible to use an official Irdeto or Betacrypte Card, which will also be opened in EMU-Mode.
TO access the Emu-Mode, please go via the ToH-Config Menu. Under 'Preselect'the following options are possible:
EMU-K (Emulator and Card):
In this mode the ECM/EMM'S as well as the EMU, go to the Card. The Card contains only ECM/EMM's through which the second known Card Irdeto are determined.
EMU-S (Emulator and Sharingserver for PW):
In this mode, a sharing server will be added in the Communication. The Connection takes place via the Seial port of the Humax.
Instructions:
1. Connect the Cardreader to PC(eg Port 1) and the Humax (eg Port 2)
2. Start CardServer
3. Settings: Add Reader, set IP 0.0.0.0 (für Server and Client am selben PC)
4. Start CardServer afresh
5. Put in the Premiere-Smartcard and check CardServer-Window
6. Start from HSIC: server-ip (=127.0.0.1) tcp-port and com-port install
7. Reset embedded HUMAX-CAM (0-RCL)
EMU (Pure EMU Mode):
This mode is not yet available. In this mode it will be possible, that EMU without inserting a card can take place.
PMCT
In the PMCT can the CAS-Systeme under EMU-K, EMU-S und EMU
serve the EMU, and write down to it. Please do not modify
@ Moppy123
<img src="/ubbthreads/images/graemlins/biggthumpdown.gif" alt="" />
De engelse vertaling is antwoord 11
De Nederlandse vertaling is post 12
van deze threat.
is het lezen in dezelfde posting al te veel moeite ?
nobody is perfect, I ain't nobody
feedback doet wonderen
vu solo2, Vu duo 4K SE, vu uno 4k,  ultimo voor hobby
@ Newbie: Je hebt gelijk, was alleen de emu prog zonder sleutels
Reeds diverse nieuwe sleuteltjes aangemaakt om het nieuwe slot te openen, tot op heden geen resultaat.
ook voor mij geld: zoek en ge zult vinden, en vinden zal ik ze.
Rome en parijs zijn ook niet op 1 dag gebouwd.
voor alle newbies: google je suf en stel geen overbodige vragen.
Is zelf niet nodig.
Ik heb maandagavond rond 22h30 de tread GELEZEN, ik denk dat er nog maar een stuk of 20 postings in stonden.
Rond 23h00 draaide de emu in mijn 5400.
Zo moeilijk is het toch niet?
DM920UHD
Yupsikidee, t'is weer zwart op tevee.
Ik stoei hier even met de DSR 9500.
Een leuke optie ondekt.Weet alleen niet of het werkt omdat ik hier om m'n plek geen Humax bij de hand heb..
Als je de file opent dan kan je de interne lege key file
openen.DAARNA kun je weer file openen en gaan naar Soft cam key opties en door scrollen naar local en mapje openen.En wat blijkt? je kunt nu iedere willekeurige
soft cam key file in laden !!!Het venster wordt zelfs groter met rechts alle key's.!!
Alleen de vraag is nu of deze keys werken..
dat zou wel makkelijk zijn omdat je dan niet meer op zoek hoeft naar een bin file...
grtjs JV
Volgens mij zit in de softcam zelf geen conax sleuteltjes, als ik de softcam open zoals je zegt krijg ik bij conax alleen maar 00000000.
Echter...... als je ipv load .."update key buffer" gebruikt nadat je de key.bin hebt geladen werkt het beter denk ik. Dan zit er iets anders dan 00000 in het conax gedeelte. Ik kan dit nu niet testen omdat ik ff geen tijd heb..zit met een "deadline" die een half uur geleden reedsverlopen is <img src="/ubbthreads/images/graemlins/grin.gif" alt="" /> en mijn humax is echt heel lastig los te kopellen.
*** Humax 5400Z Loader H2.08 TOH 3.4_HoT EMU 10.0 Triax 110 STAB 120HH ***
Wel als je de juiste Softcam gebruikt. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Gisteren mbv bovenstaande procedure nieuwe keys in de emu geladen.
Azbox Elite, SAB explorer PVR SC
Resumerend:Eerst de interne lege key file openen.
dan dus softcam key importeren via:file>softcam key>local>
mapje>softcam selecteren en openen.
En dus checken of de sleutels van alle coderingen er zijn.
Toch is er iets vreemds:De veldjes blijven vaak leeg maar DSR opent een extra veldje ernaast waar de keys op een willekeurige volgorde getoond worden.Dat kan bv met N*Gr* best maar volgens mij niet bij de anderen coderingen.
Maar ik lees dat het dus bij jouw werkt.Heb je precies deze weg gevolgd??
grtj JV
Ik ben tot nu toe geen softcam tegengekomen met conax, wel ben ik bin (RAM) files voor de samsung tegengekomen, die kan ik ook openen, weet niet of die iets meer bevat, weet niet meer waar ik het gedownload heb, was zo niet slim om de site niet op te slaan.
ik merk wel dat de cpu van de humax nu meer belast wordt, de info balk wat normaal vloeiend verdwijnt gaat nu schokkerig uit beeld.
Bij mij loopt de Hum ook vaak vast of word retetraag als ik op de Taq.. kanalen ben geweest.
Verder wel helemaal top van HoT trouwens!
Effe een paar extra vraagjes om dit draadje nog langer te mkn:
Emulatorek krijgt nagra D+ op de Hispamet deze firmsoft bij mij, bij jullie? CAS1 ook geprobeert.
En kan het ook niet aan de settings liggen, ik gebruik Petjes humaxsettings.
En moet je nou wel of niet die PMCT erin gooien?
Ik heb ook een disecq motor, daar zou het ook nog aan kunnen liggen. Mijn loader is trouwens L2.08...
Vu+ Ultimo4k
1 FBC DVB-C en 1 FBC DUAL DVB-S2X
OpenPli 7
Kijk maar een op de bekende upload sites bij J F K, die heeft een softcam met conax. <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
grtj JV
Het ging bij mij ook beetje vreemd, maar het werkt wel! <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" />
ik zal het nog eens uitzoeken.
