hemertje Geplaatst: 28 januari 2005 Geplaatst: 28 januari 2005 Musicbob heeft weer een nieuwe beta: Welcome to a new BETA preRELEASE of FlashWizard PRO. What is new on this beta: * support of images installed on NFS mount, you can install and start multiboot images on your Windows PC!! * You can install images wherever you want, on USB and/or HDD and/or NFS. * New FlashWizard bootmenu (v1.1): - automount NFS device at boot; - display which devices are connected (USB-HDD-NFS); - display where the currently selected image is installed (USB-HDD-NFS); * If NFS server is down, FW will automatically boot-up from other available images, or from flash image. * various improvements and fixes. ======================= What is required - please read carefully - : for NFS install, a NFS server is required running on a remote PC. I tried many NFS servers for Win XP, and found Microsoft's "Services for Unix v.3.5" the best and stable choice ever, and also it's free software, it is possible to download it from Microsoft's home site (approx 220 Mbytes). DON'T EVEN THINK (I repeat: don't even think!!) to manage it working on crap NFS servers, like "TrueGrid" or similars... they DO NOT absolutely work, because they DON'T support unix attributes and/or symlinks and other unix filesystem specifics. I found also the "Omni NFS Server v.4.2" working good... but Microsoft's SFU is much more stable. Please note that MS SFU does not install on Windows XP HOME editions (only XP PRO is supported). The "Omni Nfs Server" installs also on XP HOME. ========================= Installing and configuring a NFS server is the hard part of the job, if you never did it before..... Before install, make SURE to have all permissions on your Windows PC, always install the nfs server as Administrator, to gain full access on files and folders. There are some docs on how-to install MS SFU on Windows machines... try to search them with google... After server install, define a shared directory on nfs (it's called an exported directory), and write its name on FlashWizard's "PC export" input field (on Multiboot window), plus write your PC IP address on "Pc IP" text input. That's enough, FlashWizard will automatically manage the rest. I tested many images on NFS, installed on my XP PRO windows PC, all the latest are perfectly working (DBF, Gemini, Hydra, Triple xXx, ruDream, SF Team, etc. etc.). I used original beta 108.2 from DMM in flash. I found some problems with the monster-backupped images (like DVB-ER, and similar)... but no problems with standard sized backupped images... it seems like a file limit on the nfs server side. But all the standard installed images (*.img) are working perfectly on windows nfs server. Have a good testing......let me know...cu later. Download op sjerom DM8000 + DM800SE + VU+DUO + Wavefrontier T90 + 10LNBs Hemertje.Dreambox Webmaster Sat-nerds Moderator Plinux Member
Gast Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Dit werkt als een tierelier! Heb hem geinstalleerd met een Debian Linux server en het werkt perfect via NFS. <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
hemertje Geplaatst: 29 januari 2005 Auteur Geplaatst: 29 januari 2005 bij deze een indruk: DM8000 + DM800SE + VU+DUO + Wavefrontier T90 + 10LNBs Hemertje.Dreambox Webmaster Sat-nerds Moderator Plinux Member
michel130 Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Hoi hemertje, De link op jouw site is <img src="/ubbthreads/images/graemlins/angel.gif" alt="" /> dood. als ik hem heb gedownload dan is de rar file niet meer goed. Kon niet zo snel vinden waar ik het moest melden op jouw site , dus heb ik het maar hier even snel ingevuld. Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4
Gast Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Werkt weer als 'n speer! Heb nog niet geprobeerd, of ik 'm ook voor de DM500 kan gebruiken, want daarvoor is NFS natuurlijk ideaal. Ik heb 'm inmiddels bij de downloads op m'n site gezet.
Transpondertje Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Probeer alleen nog een goede handleiding te vinden valt niet mee voor geen linux kenner <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> VU+-Ultimo4k + VU+-zero4K + Multibox 4k + 100cm 13-19-23-28 + 110cm Dish + SG2100
Gast Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Ik heb Microsoft's SFU ff gedownload en geinstalleerd. Tjonge, wat een log programma is dat zeg. dat wordt een behoorlijke studie dit weekend . Zijn er al meerdere personen met het zelfde bezig ? Volgens Music Bob is dat het meest stabiele programma, maar hij is een programmeur en ik een leek . maar het blijft hobbien. weer een uitdaging gevonden. <img src="/ubbthreads/images/graemlins/loldev.gif" alt="" /> gr, RuKo
Gast Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Citaat: Probeer alleen nog een goede handleiding te vinden valt niet mee voor geen linux kenner <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> Hmmm <img src="/ubbthreads/images/graemlins/confused.gif" alt="" /> Vind dit nou niet bepaald 'n Linux tool! Als er iets makkelijk te gebruiken is, dan is 't FlashWizard.
M€®LïÑ Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 klote download.. ik heb altijd problemen met downloaden van die site staat hij ergens anders ook? Denk eerst eens na voordat je een scherpe opmerking maakt !!!!
John van Dreumel Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Zoals bovenstaand staat aangegeven. Bij satellite Europe staat hij ook op de site. Dan moet 't toch lukken lijkt mij. Greetz John Er is zoveel te vragen dat ik het tóch eerst zelf probeer uit te zoeken. Dat is ook verrekte leerzaam. Mijn boxen zijn allemaal powered by PLi.
hemertje Geplaatst: 29 januari 2005 Auteur Geplaatst: 29 januari 2005 Citaat: klote download.. ik heb altijd problemen met downloaden van die site staat hij ergens anders ook? ik heb er ff een zip file van gemaakt, blijkbaar heeft de server problemen met een rar bestand... de download is nu weer in orde misschien is het verder goed voor je om de startpagina eens lezen: Citaat: Help, ik kan niet inloggen of registreren! Het is niet XOOPS waar Dreambox.Sjerom.com op draait die dit probleem levert! Het is vaak te danken aan een Firewall of de internetbeveiliging. De meeste mensen gebruiken een Firewall software die de http headers blokt, of je internetbeveiliging staat te hoog! Dit betekent dat XOOPS niet kan verifieren of een gebruiker is ingelogd of niet (het gebruikt een cookie en http headers daarvoor). Oplossing: zorg ervoor dat de Dreambox.Sjerom.com site is toegevoegd aan de vertrouwelijke lijst van de Firewall software en/of dat de Firewall software http header info en cookies accepteert! misschien dat dit je verder helpt! succes.... DM8000 + DM800SE + VU+DUO + Wavefrontier T90 + 10LNBs Hemertje.Dreambox Webmaster Sat-nerds Moderator Plinux Member
Transpondertje Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Citaat: Citaat: Probeer alleen nog een goede handleiding te vinden valt niet mee voor geen linux kenner <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> Hmmm <img src="/ubbthreads/images/graemlins/confused.gif" alt="" /> Vind dit nou niet bepaald 'n Linux tool! Als er iets makkelijk te gebruiken is, dan is 't FlashWizard. Flashwizzard is ook geen probleem maar een mount aanmaken met dat tooltje <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Misschien wil je het ff uitleggen ?? Greetz VU+-Ultimo4k + VU+-zero4K + Multibox 4k + 100cm 13-19-23-28 + 110cm Dish + SG2100
Gast Geplaatst: 29 januari 2005 Geplaatst: 29 januari 2005 Citaat: Citaat: Citaat: Probeer alleen nog een goede handleiding te vinden valt niet mee voor geen linux kenner <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> Hmmm <img src="/ubbthreads/images/graemlins/confused.gif" alt="" /> Vind dit nou niet bepaald 'n Linux tool! Als er iets makkelijk te gebruiken is, dan is 't FlashWizard. Flashwizzard is ook geen probleem maar een mount aanmaken met dat tooltje <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Misschien wil je het ff uitleggen ?? Greetz Een usb stick kun je mounten via 't configuratie menu, daar zie je 'n speciale button voor 't mounten.
Transpondertje Geplaatst: 30 januari 2005 Geplaatst: 30 januari 2005 Citaat: Probeer alleen nog een goede handleiding te vinden valt niet mee voor geen linux kenner <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> I tried many NFS servers for Win XP, and found Microsoft's "Services for Unix v.3.5" the best and stable choice ever, and also it's free software, it is possible to download it from Microsoft's home site (approx 220 Mbytes). DON'T EVEN THINK (I repeat: don't even think!!) to manage it working on crap NFS servers, like "TrueGrid" or similars... they DO NOT absolutely work, because they DON'T support unix attributes and/or symlinks and other unix filesystem specifics. I found also the "Omni NFS Server v.4.2" working good... but Microsoft's SFU is much more stable. Please note that MS SFU does not install on Windows XP HOME editions (only XP PRO is supported). Dit is wat ik bedoel denk dat we mekaar niet helemaal begrijpen <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> Had het iets anders moeten zeggen <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> Sorry Maar kom er met dat programma niet uit. Dus met MS SFU !! Greetz VU+-Ultimo4k + VU+-zero4K + Multibox 4k + 100cm 13-19-23-28 + 110cm Dish + SG2100
Tonskidutch Geplaatst: 30 januari 2005 Geplaatst: 30 januari 2005 jongens toch.. ik had maaaanden terug ook die suf microsoft erop, moses kriebel wat een ingewikkelde zooi. vanavond, ter illustratie dreambox zonder hdd (van bigfoot gekocht) gemini 1.04 beta 15012005 erop gefalshed ipnummers instellen zenderlijstje scammy erop effe naar de pc NFsDream aangezwengeld (portmap add / nfs add) ip nummers invullen klaar (set record path is eigenlijk al ondervangen door de file export in windows) effe naar de dreambox download plugins NFSmount 0.7 instellen klaar en hoppa gelijk opnemen. <img src="/ubbthreads/images/graemlins/grin.gif" alt="" /> niks lastig doen met giga programma's nu dit staat ingesteld kun je harstikke makkelijk ook het dreamflash erover heen knallen (das voor morgen) cheers This Must Be It- Alan Dixon Remix Röyksopp, Alan Dixon & Fever Ray
